daninthesand
Hi all. If you have ever needed to shorten your throttle cable this is how you can repair it once its cut. Of course you could use this for brake cable etc.
I had this idea to repair the throttle end of the cable. It's a modified version of how Norm describes he does the carb end. Thanks for the inspiration Norm!
Here we go.....
You need a throttle cable (duh), copper tubing (diameter depends on your exact application), tubing cutter, solder, flux, small blow torch, small drill bit, file.
Clean about 1 inch of the tubing with fine sandpaper. Its a good idea to clean the inner surface of the tubing, if you can, using a small round file. Any oxide that's there will degrade the quality of the solder joint. Drill a small hole about 1/16 - 1/8 inch from the end of the tubing, but only go through one wall. Do this before cutting the tubing to length, it's way easier.
Cut the tubing to about 1/4"
REMEMBER TO THREAD THE CUT CABLE THROUGH ALL THE PARTS OF THE THROTTLE ASSEMBLY BEFORE SOLDERING!!!!
Push the throttle cable through the hole and out the side as shown below. After its through, fray the end a bit. This helps keep the tubing from falling off while you work.
Pull the cable back, until its as shown:
Here we go.....
