think i snaped a rod on my hs need help
stewpedassle
i was trying out new carb and exhaust config ran to lean it froze at first thenfired up quitand lost all compression i can hear rod wagging before i take it apart is there a sealant needed to put it together like gasket rvt what kind of headaches are in store if i take to small engine shopwhat kinda price you think theyle charge :-||:-||
you may be better off buying another engine......having that fixed may surprise you at the register
rod 20
piston/rings 20
gaskets 10
cylinder 15
shipping 10
new engine 80
i would get a new engine but thats just me
rod 20
piston/rings 20
gaskets 10
cylinder 15
shipping 10
new engine 80
This is a HuaSheng F142 49cc 4-stroke engine, not a ChinaGirl 2 stroke.
stewpedassle, This is not a Super Titan, but it is cheaper priced:
http://www.gasbike.net/4-stroke-engine-only-2865-prd1.html
If you want to try to replace the rod on your blown engine, to seal up the crankcase seam use Yamabond #4 or Hondabond, or Three Bond 1105 sealant. They are all the same stuff. Hylomar will work fine too.
rod 20
piston/rings 20
gaskets 10
cylinder 15
shipping 10
new engine 80
there is no cylinder for the HS, if the bore is damaged you need a whole new block, and tell me where you find a HS for 80 bucks. this isnt a china doll two stoke
It's in big blues post.
That's a brargain son!
It's just a bare engine, no pull starter flywheel, magneto, etc... But you can get those parts of ur toasted engine
the one at gasbike outostock til poss end of year and other has too long of shaft need tapered shaft like super titan for my tranny looks like im eating bologna sandwich's for mnth or so til i can afford lol ARRRRRRRRRRRRRRGGGGGGHHHHH!!!
You need to take a closer look at that ebay engine.
It has the same shaft and clutch dimensions as the super titan.
The shaft looks longer on one of the photos because the clutch shroud has been removed.
The other photo shows the engine with the shroud and clutch installed.
It is the same beast.
Look for your self.
I did it with both ebay and DAX opened on different browser tabs and I toggled between the two looking closely at the photos.
Look for your self.
Looks the same to me.
Chris
AKA: BigBlue
