Filing, cutting, grinding and polishing ....these all require different dremel bits.
Each of the different places a dremel is called for should be using a bit designed for that job. For example, grinding engine mounts to make them fit, porting and polishing an exhaust, filing or grinding this or that.
Can someone give a listing of what bits should be in my tool kit and where I would use them?
I do not have a dremel tool, but I do have a cordless drill and I believe I can use dremel bits in that or at least find comparable drill bits to do the job.
