CallMePavz
Well, I was told one of the biggest problems with beginners was with the chain tensioner, and boy was that on the money...
Been riding the bike since Thursday, and haven't had so much as a hiccup. I even took a dry run to work to be sure it could handle the distance (6-7 miles) without issue and adjust my commute time. Handled terrifically.
Today was the first day I decided to ride into work on her, and I'm lucky I'm alive and uninjured!
With less than half a mile to go, I hear a sound like the chain scraping against something. Before I can even slow down, POW. The rear wheel locks up and skids to the right. I manage to regain enough control to straighten out and brake to a halt.
Surveying the damage, the chain suddenly began to rub against the corner of the tensioner mount, quickly leading to the chain breaking. It then lodged itself between the drive sprocket and its housing. This, in turn, caused the motor to be partially wrenched from the frame, shearing the lower mounting bolts (the up-tube clamp is intact).
Current required actions:
1) Replace chain
2) Remove and replace sheared bolt from lower mount
3) Replace spark-plug cap
What should I do about the chain tensioner? Should I do away with it? Should I move it? I had to put it in the vice and hammer a bend in it to get in line with the chain, but maybe that just wasn't enough?
1) Replace chain
