One main reason for going rear drum is because this bike is going to be titled and registered, and so I would prefer to have front and rear brake lights. It’s going to be a 212 with a charging coil running my lighting system, which is going to be complete with headlight, tail light, brake light and indicators. Unless there is a way I can figure out to throw a brake light switch when pedaling backwards, which I can’t think of, a lever operated rear brake with an integrated brake light switch seems like the easier option. I am looking into moped hubs now.Honestly... there's nothing wrong with using a standard coaster brake hub with a hub adapter... They're simple, reliable, plentiful & affordable... & honestly, I think they stop just as well (if not better) than a rear drum brake.
But if you absolutely have to have a rear drum just to be different, Sportsman Flyer had a lot of success using moped rear drum brake hubs... so you might consider going in that direction.
Here's a good example... https://www.ebay.com/itm/1261028764...uid=5ltfckvaRVa&widget_ver=artemis&media=COPY
Install the brake light switch on the front brake lever... problem solved.One main reason for going rear drum is because this bike is going to be titled and registered, and so I would prefer to have front and rear brake lights. It’s going to be a 212 with a charging coil running my lighting system, which is going to be complete with headlight, tail light, brake light and indicators. Unless there is a way I can figure out to throw a brake light switch when pedaling backwards, which I can’t think of, a lever operated rear brake with an integrated brake light switch seems like the easier option. I am looking into moped hubs now.
Yes…if I want to use the front and rear brake at the same time. If I want to use them independently, then both should activate the brake light. This is how mopeds, scooters, motorcycles and generally all titled two and three wheeled vehicles operate.Install the brake light switch on the front brake lever... problem solved.
Here ya go... https://www.ebay.com/itm/3938802414...uid=5ltfckvaRVa&widget_ver=artemis&media=COPY
I’m leaning more towards building my own wheel with a moped hub and maybe even 4 cross instead of 3. A 4 cross wheel with 11g spokes would be damn near bulletproof lol.Install the brake light switch on the front brake lever... problem solved.
Different rules for different states, brother. In my state, they are titled and registered.I think you're making things way more complicated than they need to be... but go for it.
Also... There's no such thing as titling a motorized bicycle... only registering them... & it's usually a 'mail in' process with no inspections
Here's 212cc bike that I built for a customer several years ago... it has 12g Felt cruiser wheels with a coaster brake & a front disc... It's still on the road & the wheels are still SOLID!!
Venice Ruff Cycles Chopper Build | Motorized Bicycle Engine Kit Forum (motorbicycling.com)
In my state, they require an initial inspection, but not yearly. The frame is already titled and has a vin, so there isn’t much I can’t do to it. I’m planning and building this to my preferences, and I’m not sure why anyone would care as long as it’s not dangerous or stupid.I think you're making things way more complicated than they need to be... but go for it.
