sturmey archer front dynamo debaucle?!
BTW - I'm glad ya liked the copper line to hide/protect the wiring & after seeing the pics of yer ride;
http://motorbicycling.com/f45/finally-here-she-boys-20704.html
(which looks freakin' sweet!), I had the thought that if you wanted you could use stainless automotive brake lines to do the same (stainless lookin' more appropriate w/yer chrome I think), but even steel ones could be painted... heck the stuff even comes in colors these days lol
Ya'd just need a bending/flaring kit, they can be cheap like this one: OTC 4503 - Stinger Fractional Double Flaring Tool Kit OTC-4503 OTC4503 OTC 4503 (I dunno about that retailer tho) - the cheapo won't like the stainless line much, but it'll work.
Just a thought ;)
thank you for the compliment!
I'm actually looking to rout the wiring through the frame... soon as I get the damned thing to work! Schwinns got those great tubes on iether side where a pinhole to run the wire through won't compromise structural integrity, I'm also thinking of trying to internalize all the rest of the wiring, I still run a killswitch, and will put that through the handlebars, skiping over the headset into the frames top bar down seat tube....? dunknow yet still figuring it out?!?
ok, try again...guess they were too big, & I didn't bother reading that....
K, that's pretty similar to my light, it does rely on the housing as a ground so that may be the problem. The "clipped" black wire you've got there is for the positive lead & looks OK (provided ofc that's the positive wire). You can solder a negative connection directly to the triangle shaped spring that holds the bezel in as it makes contact with both bulb's housings (their negative) - that's what I did with mine and it works well.
You may experience some problems with the positive, that big brass dealie that only touches the positive on the bulbs when you close the light - make sure the reflector that the bulbs are in is straight and mebbe bend the brass tabs out a bit to get good contact...
Other than that it outa work jus' fine provided you've got 6v bulbs :)
ok, just to make sure, if my connection is on the right hand/throttle side...which connection port is pos' & which is neg'?
If your facing it and the open ports are facing up, I'm pretty sure it's the right-hand port is the ground/negative & the left is positive - but double check that with yer multimeter jus' to be sure ;)
...but with incandescent (not LEDs) that wouldn't matter BTW, but might as well do it right - it'd make it easier to use LEDs later.
yup yup!
thanks to BARELY's wiring advice and a trip to lightbulbs unlimited, I now have a beautiful working bullet light and can ditch the star-trek looking crapper I've been having to get by with!
Sweet, good ta hear ya got it all worked out (^)
...I've still not replaced my burnt-out driving light w/the LED tho, I spaced it heh :-{
