steel tubing for frame?
sub66
140
canada
unless u plan on using variable thickness steel. perhaps local lengths of tubing would be more than enough. 1/16 1/8 etc thicknesses is what you need.
dont worry about grade of steel. if it truely looks great when ur done the mild steel w be cheap and ride great possibly.
3lbs light frames are not stiff so why you need good steel if u makin a beauty 6-7 lbs frame for 40 bucks or less. the triangles will be fine.
there lots available off the shelf like universal droppouts etc. but 69.99 handbuilt raw cruiser frames are available allready. maybe this helps. whats the plan?
wret
355
65
28
Maryland
I'm the first one to think of creative uses for materials they are not intended for and have done so many times in my recent board track racer build, but NOT for the frame.
Look for 4130 steel tubing. You may find it locally but there many on-line vendors.
culvercityclassic
3,115
177
Culver City, Ca
This is my choice for frame building: DOM Tube: 1" O.D. x .083" wall
You should be able to purchase at your local metal supply house at a fair price for 10 feet.
I really see no need for 4130 on a bike frame. Now if you want something special then use the 4130, you could then use .065 for a lighter frame.
