MB-Monkey
now that i have done all the things i can think of to solve the problem i am asking for a little help.
I have had the motor running well for about 2 weeks of break in. I leaned out the mix after a hundred miles and discovered the plug was too dark and oily so i replaced it. The fuel filter looked muddy so i replaced it.
The motor seems to be starving for fuel. I have the CNS carb on it and it was performing fine then i noticed the performance dropping off lower top speeds and ow it seems starving for fuel.
I took the carb off and took off the bowl nothing in it i removed the jets and made sure they were clean so i reassembled the carb and gave it a shot.
I can choke the motor out and it will stall. I have seen others that have had air leaks and i am getting some carb cleaner and silicone but not real clear on what to seal.
Does anyone have some pics of what needs to be sealed i am dying can't get it to go more than 15. with the gradual on comming of the problem i am kind of stuck.
Any help is welcomed.
