Specs for my Trek 930 mountain bike
Rusty_Nail
Hey everyone, I'm not sure if this is the right place to post my bikes specs for the build I'm attempting, but here they are. I was trying to find where I can put it on my profile so for any questions etc I have everyone will know my bikes specs. If this is not in the right place, where can I post it on my profile? The attactched pic is the same bike but mine's just a darker blue so you guys have a visual too. Thanks!
Sizes Available: 16.5, 18, 20, 22"(measured center to center)
Weight: Frame, 5.12 lbs.; Fork 3.26 lbs.; Bike 29. lbs.
Frame: True Temper OX Comp triple butted Cro-moly tubing; Rock Shox Quadra 10 fork
Wheelbase -- 42 in.; 106.68 cm
Seat tube -- 19.5 in., 49.53 cm (actual, center to top)
Top tube -- 23 in.; 58.42 cm (effective)
Head angle -- 71 degrees
Seat angle -- 73.5 degrees
Chainstays -- 16.875 in.; 42.86 cm
Bottom bracket height -- 11.75 in.; 29.84 cm
Fork rake -- 1.5 in.; 3.81 cm
Trail --2.89
Wheels:
Hubs -- Shimano STX, quick release, 135-mm rear axle spacing
Spokes -- 32, 14-gauge DT stainless steel, 3 cross
Rims -- Matrix Single Track Comp
Tires -- Trek Control Track system, 26x2.1
Drivetrain:
Derailleurs -- Shimano STX, Shimano STX Rapid-Fire Plus shifters
Chain -- Shimano Hyperglide
Crankset -- Shimano STX, Shimano STX steel rings, 175 mm crankarms
Bottom bracket -- Shimano Cartridge
Freewheel -- Shimano 7-speed cassette
Components:
Brakes -- Shimano STX
Pedals -- Trek System 1; nylon clips, nylon straps
Headset -- Dia-Comp "Aheadset", 1 1/8 Oversize
Seatpost -- Trek System 1 6061 T6 alloy, 300 mm
Saddle -- Trek System 2 Gel
Bar/stem -- Trek System 2 6061 T6 alloy bars, Trek System 2 Cro-Moly 14 cm. stem, Trek System 1 Bar-Ends
