Spark Plug = no rear movement
Discussion in '2 Stroke Bicycle Engines & Kits' started by jliehr, Mar 24, 2013.
  1. jliehr
    jliehr New Member
    Mar 24, 2013
    6
    Hi,
    I'm on my way to creating my very first motorized bike and I'm having some trouble with the rear wheel. With the spark plug installed, the rear wheel will not move whatsoever. If you take it out, the bike gladly moves and works. My only issue is why is this happening? Also, how could the spark plug even be interfering with the rear wheel not moving?
  2. wan37
    wan37 New Member
    May 29, 2011
    343
    what kind of engine do you have?I will help,many others will too.
  3. jliehr
    jliehr New Member
    Mar 24, 2013
    6
    2 stroke china 66/80cc
  4. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    Is it like this wether the clutch lever is pulled or not?
  5. jliehr
    jliehr New Member
    Mar 24, 2013
    6
    with or without, it wont move either way.
  6. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
    Welcome to the forum. Here's an answer to your problem - which really isn't a problem. Suggest you do a search 1st before posting your problem in the future. This forum is full of information. There probably hasn't been a problem that hasn't been solved.
    http://motorbicycling.com/showthread.php?t=45864
    Good Luck,
    Chris
    AKA: BigBlue
  7. wan37
    wan37 New Member
    May 29, 2011
    343
    Ok you have to have the clutch lever and cable hook up and pull in for the bike to move after you get speed up let in out to start it
  8. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    That^^^
    Was thinking of the same post.
  9. jliehr
    jliehr New Member
    Mar 24, 2013
    6
    Hi,
    Thanks, I was unaware of that thread. Thank you. Again though, how do I go about adjusting my clutch? According to that thread that is the problem. This is my first build so I'm not quite sure of many things so bare with me.
  10. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
  11. jliehr
    jliehr New Member
    Mar 24, 2013
    6
    Great, watching it now. Thank you.
  12. 2door
    2door Moderator
    16,286
    This> http://motorbicycling.com/showthread.php?t=22729 is one of the best and most easily understood tutorials on proper clutch adjustment. Thanks to Gearnut for it.
    In addition to your clutch not being adjusted properly the clutch pads could be stuck. This is a common and easily fixed problem. You can find the remedy if you use the Google Custom Search and use the key words "Stuck Clutch Pads". Good luck.
    #12 2door, Mar 24, 2013
  13. jliehr
    jliehr New Member
    Mar 24, 2013
    6
    Hey guys, I am getting very angry with the bike as I've done all the above steps multiple times and the bike still will not move. I am posting more pictures of the clutch itself below, please tell me if there is something I've done wrong or out of the ordinary as I'm already bashing my head in on the seat on this one.
    http://imgur.com/a/44qPH
    Thank you.
  14. 2door
    2door Moderator
    16,286
    First thing to do is remove and discard the small spring between the cable guide and the clutch actuator arm. It serves no useful purpose except to make the clutch harder to pull.
    There is a jam nut on the cable guide. If you loosen it you can rotate the guide so it points more directly toward the clutch actuator arm. Retighten the jam nut.
    Next run the handlebar lever adjustment all the way in toward the lever then tighten the cable stop so you have little to no slack in the cable. Don't make it bow string tight but just snug. Some say to give yourself some slack, maybe 1/8" of free play. I prefer tighter than that.
    After you do those things get back to us with what happens.
  15. maniac57
    Oct 8, 2011
    4,493
    Make sure the chain is not hung up on the inside of the sprocket cover. I've had some kits that required grinding the cover, as well as some that needed the edges ground off the sprocket teeth to allow the chain to move.
  16. tooljunkie
    tooljunkie New Member
    Apr 4, 2012
    663
    that spring goes over the cable "sheath" and is located where the clutch cable runs close to cylinder.to keep from overheating cable.
    my engine was tough to get rolling at first. it took some hard pedaling and a few attempts to get it rolling enough to make it fire.
  17. 2door
    2door Moderator
    16,286
    Sorry TJ but the small spring isn't a sheath. The larger one is and protects the cable from heat and chafing against the cylinder fins. The smaller spring that the kit instructions tell you to put on the cable between the clutch arm and the cable guide is not needed and only increases the clutch pull force. It is not required to pull the clutch to the engaged position.
  18. tooljunkie
    Apr 4, 2012
    663
    You are right tom, my mistake. I thought it was the bigger spring on there
    Guess i need to pull the beast out of winter
    Storage and refresh my memory.
    My apologies to op if i created any confusion.
  19. supercub
    supercub New Member
    Nov 1, 2012
    56
    Best thing to do to understand the hangup is to go on ebay and buy a gear puller for less than $10.00- Boygofast or any bike engine seller. You can use the puller for the small crank gear, clutch, and the sprocket. Take the small crank gear off first. Watch the woodruff key. Push the piston down with a piece of wooden dowel rod. If it is free, remove the chain and turn the clutch. It should rotate. You will need this tool for future work you can count on it.
    I use the spring over clutch cable just so the arm doesn't vibrate around. Any little thing on these bikes will make alot of noise if not battened down.
