Took a minute, but I think I have it now...About the blown head gasket/cover, here they are. The first two are the cover and the gasket, pretty obvious. I feel like an idiot.
The most important thing is keeping the surface flat as you clean up the gasket surface area. You don't want to sand an angle into it or have high or low spots. Go slow and don't apply too much pressure but concentrate on keeping the mating surfaces flush with each other. I hope that was understandable.Yeah, I guess I didn't realize that they would loosen off, in bigger motors they don't. Gonna buy upper and lower gaskets, exhaust and intake, too I think. BTW, will the sandpaper on glass thing give me a good enough seal, or should I buy a new cover? Oh, yeah...except the head nuts and loctite.
We only advise against the red lable product which when used with aluminum castings can be next to impossible to remove without applying heat in excess of what the aluminum can take. If installed/ assembled correctly there is really no need for thread locking products on these engines and kits. Vibration can be an issue nevertheless proper installation and tightening of fasteners will negate the need for LocTite or any other thread locking materials.Why all the hate on the locktight? Get the blue and and its easy to break , and your bolts don't loosen off. I see no reason not to lock tight everything.
Initially torque them to the specs given above then again after the engine has reached operating temperature. From that point do not try to tighten them again. Use a torque wrench, if available, and only go to the recommended value. People get into trouble when they believe that there is no difference between 'checking for tightness' and 'tightening'. The ones who usually strip threads are those who think that 'checking' means getting the nut to turn 'just a little more'.How often do you check the head bolt torque.
