Soft springs on new seat
Discussion in 'Motorized Bicycle General Discussion' started by Toothy, May 16, 2014.
  1. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    Wow nearly every week I hear about a spring rubber being added in NASCAR.
  2. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    You might be able to take a short length of 1/4 -5/16" or 3/8" black automotive fuel line and split it so that it will slip over and around the springs, then maybe two or three thin black zip ties could be used to secure it at each end and maybe one in the middle, if done right it wouldn't look bad and that would for sure add extra support.
    Lay the line down flat and with a sharp utility knife just cut a slit down the legth of the hose and then install it over the spring.
    just the first thing that came to mind, might be worth a try if the tubing you're using now doesn't hold up well.
    Map
    .wee.
  3. turnofftheradio
    Sep 4, 2012
    242
    Neat fixes so far. I'm only 160 and my springs are still a little soft. Mine is a bit different, its very comfy, but it has a second set of springs underneath and a sway bar. I'm not sure if your seat could add the second set like mine or not. I'm going to play around with all this too. thanks! [​IMG]
  4. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Map,
    You were right on. I feel a little bitter cause the seat didn't do it for me but a lighter rider may be fine. I will say that the parts are very weak, crappy metal, very easy to bend...just cheap. I gutted the seat several times, bend springs...no better. Then in the true spirit of this hobby I used the base of another spring seat and presto! Much better.....not a complete result yet
  5. mapbike
    Mar 14, 2010
    5,380
    Well the main thing is that I hope you can get your seat to the point where your happy with it and its comfy and safe for the backside, having a good comfy seat that stays where you want it is important on these motorized bikes to me.
    My seats aren't the coolest and sportiest looking seats bit they are duable and comfortable for the long rides I make since I live several milea out of town, 30-45 mile rides are not uncommon for me in a day, so comfort trumps the coolest looking seat for me.
    The good ole wide cushy cloud 9 seats are my favorite so far.
    Map
