Once I saw how much motor mounts cost for the four stroke motors I've been thinking about how to make one for the Greyhound. This is what I came up with for my 51 Schwinn cantilever framed bike. The hockey pucks came to mind from something I saw a long time back using one for the rear mount on a China girl. I don't know who thought of it first and don't recall now how it was done, but credit should go to that person for being the first to use a hockey puck. For those who do not live in hockey country, the puck is a very hard rubber disk meant to take a lot of punishment and responsible for knocking out a whole lot of teeth all over the north land. This is not soft rubber. So the idea was to use two of them, one on each down tube and to drill the 1" hole at the same angle as the tube so that the flat of the puck would be parallel to the ground. I used a spade bit and realized it was every bit as difficult boring through that puck as it would have been with a fairly dense wood. With those drilled I laid out the U bolts, traced them onto the pucks and drilled holes from side to side. Then I used a sabre saw to first cut off part of the disc so that it would have a flat face on one side. Then I cut from the flat edge to the angled hole in the center. I did not cut through the whole disk. Tried them for fit. Since the curved edge has not been cut through it is possible to spread the puck open to fit it around the frame. Look good to me...
Cont.
Cont.
