mew905
So I spent the last oh... 5 hours trying to figure out how to shorten my melted throttle cable. I bought size 4 Split shot weights, because they slipped into the brake lever hole. As well as a new generic brake line (for the outer sheath). Got home, turns out the split shots are waayyyy too soft to be useful. So I ditched that, and tried to solder (normal rosin core, I cant find silver solder). Solder doesnt stick to the brake line. I was ready to give up... then I thought... what about the small crimp butts? So I came up to my following method that actually works!
Take off your throttle cable, completely, you need to know how much "Draw" you need for the throttle. The RT carb is about 78.5mm long, I havent measured the standard NT carb yet, but the method is the same
Step 1: Measure the cable draw (how long it comes out one end when you pull it all the way)
Step 2: Cut off the throttle nipple, you wont need it
Step 3: cut your throttle outer sheath to the length you want it, the part that enters the throttle grip is crimped on, so you need to cut the other side.
Step 4: measure out your draw length and cut the actual cable at the proper length.
Step 4b (RT carb only) put the carb cable guide on the cable BEFORE putting the new throttle nipple on the cable. Trust me, this will save you a lot of headaches and filing.
step 5: Crimp a 18-24ga. electrical butt crimp onto the end of the cable (the small red ones), take the plastic off however you choose (I melted mine off with a torch). Leaving only the metal crimp.
Step 6: Cut the crimp end to about 5-6mm using side cutters. Slip into throttle slide, and reassemble, and enjoy
Successfully shortened my throttle cable to 33 inches using this method. Throttle is snappy again for once. watch the nipple length though, carbs have an area where the nipple can catch and leave your slide sitting high, round it off if you need using pliers or another tool.
