colemanbales
Hey guys, so heres the deal. I had been running my bike without the head nuts/ bolts at the correct torque for a long time, and read somewhere that it was a good idea to torque them to around 120 in/lbs. so i unbolted the nuts,took the head off, and used two nuts tightened together to torque down the bolts. everything went fine, and i got it all back together and torqued down the nuts as well. once it was together, i realized that the engine would not turn over (great timing right....). Its only when i have the clutch let out that this happens, when the clutch is in i can still ride it like a normal bike. so i took the head off of the engine, and saw that sure enough the piston would not go up or down, and the back wheel was locked when the clutch was out. I thought this was particularly strange, because everything worked fine as i was working on it,and before then, but as soon as i had torqued the bolts and nuts, it wouldn't go. I also tried removing the bolts all together, but no luck, it still wont budge. Any ideas?
