Schwinn hub adapter
DNG
Do any of you guys know if anyone makes a hub adapter for a Schwinn Deluxe 7. It has 7 internal gears. The hub is 2 3/16 inches on one side and steps up to 2 5/8 inches on the other. Thanks in advance.
I suggest simply getting another rear wheel... find one with thick spokes & a coaster brake.
You really don't need the pedaling gears once you have a engine on the bike.
Thank you. That is what I will have to or use a spoke mount. It's just that I have heard bad things about going that route. Thanks again.
The spoke mount sprocket won't fit over that large flange 7-speed hub... :(
Just get a new wheel & use a standard hub adapter & billet sprocket. ;)
If it's worth the money you might find a machine shop to open up the inside diameter of the sprocket to fit the flange. You may have to also have them drill you 9 new holes in the sprocket so the pineapple clamp will adapt, the clamp will need changing also.
