SBP pipe springs
oldspeedsi
Ok so i have the SBP pipe but I am having a problem the springs to hold it on keep braking is there anywhere to buy the springs only i have checked SBP but i do not see them help if you can lead me to a source.
We will gladly replace your springs for you. One thing to watch is that the rings that are welded onto the pipe to catch the spring have sharp edges and can cut the spring over time. It is wise to file the sharp edges down on the rings to avoid this. This is covered in the installation manual. You can also use some safety wire as a back up so if the spring does break you can still make it home.
