Okay took the 33Saw for a good 10mile test run and it ran great aside from a few gliches. Its a no clutch friction drive with a pivot lift when stopping.
Problems:
I put a heavier spring which helps with the roller bounce off the tire when hitting big bumps but it does add more tension on the pivot lift lever or (aka cable clutch), which is going to put a toll on my hand when hitting the stop lights. I did the additional brake lever for the roller release.
When i hit a big bump, and if the roller bounces off the tire it will release the lift cable off the top pulley. Im thinking of adding a spring at the end of the cable but im afraid the cable might shear from the friction of it sliding through the cable stop hole. I hope that makes sense.
I do notice some considerable wear on the tire due to the stop and go action. Im pretty sure it is mostly from me giving to much gas before lowering the roller when starting from a stop. I'll have to get used to the throttle.
All and all, the Throttle setup works great, the 1.5" peg with tacks gets me up to 32" no prob., and the gas can works great also. I fugure 32oz. should get me about 30miles+.
Any suggestions on the release cable bouncing off the pulley would be greatly appreciated.
Here are some pics of the pulley setup and the roller with tire wear. The roller is pretty knarly so i think im going to sand down the tacks a bit to see if it helps with the wear.
			Problems:
