Safe to mix 2 types of 2 stroke oil
Rusty you can make your own gasket out of thicker material and only use one, the template is in the instructions section.
Gumping up the pipe is much preferable to seizing up the engine. Factory says 16 to one then run 16 to one. Oil is cheap.
I understand your concerns, 32 to 1 won't seize your engine but if you are going 16 to 1 you might want to check your pipe often to make sure it doesn't get clogged with oil, especially if you are using a stock exhaust pipe.
Thanks Larry. I'll keep your offer in mind, for now I'm going to try the templates. I printed them out and happen to have some gasket paper laying around the garage. If that doesn't work I'll hit you up.
