Howdy folks.
I have to hold the throttle a little bit to idle. How can I make it so that I don't have to hold the throttle to idle? My throttle cable is already adjusted as tight as possible. Should I cut it and shorten it?
Solder the cable before shortening it so it doesn't fray.
Have you tried adjusting the idle screw? Which carb are you running? If its a cns2 the screw closest to the red air filter cover is for air mixture at idle, turn it ccw to increase air flow and it should increase engine rpm.
