Kauhna,
I've read in several of your recent posts that the HS142 or Honda Motor weigh 15lbs? Where did you come across this specification? I run a Honda GXH50 in frame and the motor weighs approx. 10 lbs not 15lbs. The HS motor seems to be a very good motor. and its hard to beat the Price. The version with the 5/8 shaft is probably the better way to go than the CC version in my opinion as it gives you the most options for reduction drives etc. If you could hold out until the folks at bicycle-engines get in their new shipment of Grubee Kits you could put together an inframe kit for probably $400.00? I know you would still have some challenges to make everything fit the bike you have, but I've spent some time checking out the bike a a couple of local wal-marts and think it is a very doable set-up to put one of these 4-stroke kits in frame in that bike.
ocscully
