Rim & Hub redrill
Joemamma
Hey all,
Has anyone here had to redrill there rims and hubs to be able to accept 12 gauge nipples and spokes? If so, what size bits did you use. I would take a guess but I don't want to over or under size the holes. Thanks for any info
i do it all the time, but i don't remember what size bits i used.
honestly, i just eyeballed it.
Is it that you've not got the spokes yet & are planning on having the wheelset laced by someone else? If so - I'd hold off till you have 'em or ask at your local bike shop for a spare/spent 12g spoke & use it to size with a drilled test piece/drill index ;)
Finding the drill bit size is not a problem, just wanted to know if it is important or not to have a little clearance or a tight fit. Maybe I'm over thinking this.
What I do when I re-drill since every manufacturer seems to use different size holes, I find the hole size by using drill bits and then go 1/64" over. Has never not worked and more importantly has never had a spoke nipple pull through.
