rohmell
I have a piston and cylinder here that got scored by an errant needle bearing jumping up from the connecting rod's small end.
I am planning an experiment which will involve filling in the scored area with some aluminum brazing/welding rod (Alumiweld/Alumaloy/HTS-2000) and then machining the areas back to normal dimensions.
The rod melts around 730 degrees F (388 degrees C) so it should hold up in a normally running and correctly tuned engine.
I plan on taking before/after pics and posting them all here.
I know a replacement piston and cylinder are cheap, but I have a ton of these rods sitting here, so I going to give this a whirl.
