removing valve keepers, 97cc engine
kart35
What's the trick to releasing the valve keepers on this flathead engine? This is the engine off a Baja DoodleBug minibike with 97cc 4 cycle engine.
Thanks, all replies welcome. :-)
Do you have a pic of the engine you're referring to? 97cc Lifan, B&S, ? Normally you compress the springs to get the keepers off.
dnut
Valve retainers on most flathead/sidevalve engines typically aren't much different from an OHV engine.
I found the attached pic on a parts.pdf for your engine. Sorry it's sideways, only way I could resize it so it's attachable and readable.
Hope this helps!
Years ago I bought a valve spring compressor from Sears made specifically for small engines. It looks like a goofy C clamp with 2 extended fingers on the stationary jaw. Works well.
If you are in a place about saving money or money an issue at this time to buy the tool needed? A valve spring depresser can be made from a pair of large vise grips. That is if you have the extra metal around (as it is a minimal amount of steel) and access to a welder. I use Arc Welder myself.
Last I made like this, was to rebuild my cousin's Chevy Vega. As they were wanting over $200.00 to rent one of their valve spring depressors for his 4 cyclinder. Good luck with your project!
.shft.
Well that one is a whole lot different that what I have, but I can see how it would operate.
It also looks easy enough to make with some scrap flat stock for free.
I have the c-clamp style too, but the end that goes over the spring is too large for 97cc springs (works perfect for ohv 200cc engines).
At approx $20 total w/ shipping, I think I will try to make the tool. :-)
Thanks, for replies.
Too be honest, they way I do it normally is just using my fingers. Unless the valve springs are more that 40lb. (which most aren't) my fingers work just fine.
dnut
OK, got the engine completely disassembled. Now need torque specs and ring gap specs, so I will start new thread. Thanks :-)
