exokinetic
So do you think it was running too lean, burning that hole in the piston?
Ohh yea, that was way too lean
Plug was white with little speckles of aluminum
Whenever you add a reed valve you need to jet the carb real BIG & then carefully test smaller jets until the 'sputtery' feeling goes away, (& then stop)!!!
Jetting any smaller will feel like there's more power but it's actually getting close the 'too lean' territory that burns pistons!![]()
I can't say anything bad about the stock carb, it idles perfectly and throttle response, I couldn't ask for more from this chins motor. Wondering if I lengthened the runner from the reed valve to the carb, would that give me the low end torque I'm looking for?
its torquey, because it makes no horsepower.
Yea I hear yah on the water.
And I have seen tests that show there aren't really any filters that work great a preventing water transmission, without hurting performance.
Seems like it is just an unfortunate fact of life... another benefit of the air-box style set-up, and hiding the inlet somewhere out of the air-stream + fenders to keep water from spraying all over the bike.
Outerwears silicon impregnated screen will keep water out of your filter.
http://www.outerwears.com/
I'm not using it on the MB yet but they work ok on the KTM.
These motors are so easy to experiment with.
Last winter, before I bought my new camera, I tried various "airbox" shapes:
The long "trumpet" at top was a torque monster but no speed.
This was the best one.
Some JB Weld and a waterbottle on a jar lid, too easy.
Test them on a hill with a GPS as a speedo.
Cutting the bottle at an angle broadened the power spread and is easily angled to miss the mud spray off the tire.
Cuz we can't be afraid of a little rain can we?
I had a problem with the stock filter letting dust through, damaging the cylinder.
This finer foam is working fine. You are right about getting the carb as close to the piston for signal too.
I'll probably mount the carb closer yet later. Extending the bottle "airbox" gave worse performance.
I need more shortness!
Steve
This looks like you bought the wrong piston for your bike. There’s some that have the long rod and some the short. You have to get a high or low hole piston and it looks like it jammed into the spark plug and broke a hole. That’s what it looks like from the picturesHere's pics of experiment gone bad
Thanks a lot for the kind words man!
Bike #124, and Bike #154
Apollo Moto Racing, pushing through the limit.
Hey Exo,much respects to you and yours.Bro I could really use your help.I'm currently dealing with the issues that come with installing a reed valve.What I got is one of those "RawRacer IIIs" which consist of a YD100 w/a GT80 reed valve and Keihin carb clone ass.I've tried looking up this carb for info on how to tune it and where to get jets and its been a struggle the whole time.And still cant get no info ,no instructions on how to set,nothing And I'm pissed.I've already port and polished my head and tonight I'll install a window piston.Have a nice size expansion chamber arriving today.So what else do I need to do?I'm hearing something about a" third transfer port""?And that I'll have to change jets, and tune carb?Bro I have no problem doing anything,I just need someone to explain to me what I need to do and how.Got a top notch bike that I just built that's made to go fast,now I need the motor.Working to hit 50 mph.Been hearing really good things about you and your builds.Can you help a fool out?Thanks a lot for the kind words man!
