How fast are you going at 9200 rpm?i have a 80cc china girl it has 26" rim 44t sprocket and i ride 28+ miles a day between 6000-6800 with bursts up to 9200
I found out how fast it shouldnt gonow Im still trying to find the right piston to replace it!![]()
The piston pin hole actually could have moved from exessive heat. I had that happen to the gear driving the transmission of my nitro rc car. (except that gear was a plastic one.) If the piston pin still fits, then it will probably be fine. Worst case scenario: You have to change the port timing, but also get a higher compression ratio. Just make sure the piston won't hit the spark plug, or cylinder head.
Definitely not and definitely not and complete non-sense. They're just two different pistons, they're not interchangeable and that's all there is to that. Try again.
