A few weeks ago I posted a thread about a vintage treasure hunt. One of the finds was a cool old seat which had seen better days. It was bent, had no upholstery and was sitting very much out of place on a 24" girls bike. Another find was a 51 Schwinn cantilever bike with a springer missing parts I decided the seat would be just right for the 51. I took the seat apart so that I could remove most of the rust with a wire wheel, then gave it a coat of paint. I also put it in the vice and straightened up the support frame. Today while waiting for paint to dry on the springer forks for the 51 I upholstered the seat. This is how I went about it for this seat. I've done others in harness leather and the approach is different. Another time I'll show how to do that.
So I cut out two layers of foam and attached them to the seat itself using contact cement. To use this kind of adhesive effectively you need to apply cement to both surfaces being bonded and leave each alone until it sets up enough to be tacky. The press them together and it is amazing how well it holds. Good stuff and the only kind of glue for this job. So, one layer at a time I adhered the foam to the seat. Then I cut out the elk hide a little big and again used contact cement on the main part of the seat... not the edges. Once that was set up I applied cement to both seat and the edge of the leather for about one quarter of the perimeter. Once pressed together I used cloths pins to keep it that way.
(Cont.)
(Cont.)
