Rear wheel bearing keeps coming loose
update: last thing i tried a while back was to straiten my axle and repack bearings. i stuck my axle in a pressed and straitened it, cleaned and packed bearings and installed. been well over 50 miles with zero trouble to note.
Did you hit a pot hole or curb, or was it bent from the gitgo?
Maybe walmart owes you a wheel..
Us eighth-of-a-tonners have to stick together.
lol. i think it was bent from the get go. tahts why i recommend checkig yours. my hub seems to be good now but as you know with my otherp ost, i have other issues.
i have same problems with my rear wheel, my solution was cange tensioner function, adapting it to the chain with a spring, so, the engine wil not hit again and again to the wheel, that kick its compensed by the tensioner, my rear wheel has stopped to break as the moment i change the tensioner, for security purposes only i modified the frame, so the fast lock can be safe to use and wheel keep aligned with engine and chain and keeps in that place, if you need to make some correction, its too fast to do it, sorry for my yoda's english jajaja im from Argentina, so it's a miracle i can read and write in english jajaja
have a nice ride
Sent from my GT-I9300 using Forum Runner
have a nice ride
That's a great idea and I like it. But my problem was the wheel bearings kept coming loose. Not the axle or chain.
i know, the only thing you need to make in your bike it's the springer tensioner, i have a vid with its function, and there you can see how compensation works, i change 4 times the wheel bearings, before make the tensioner. and I always use skf heavy duty bearing, i start yo inquiry in the promblem and found that the engine kivks too hard in the wheel, and the issue stops in the moment i adapt the tensioner.
