I built a springer front fork rather like a 1910 Pierce and the frame I had to use to accommodate the short stem was a Otasco lightweight 24". This made up my mind to build a spring rear end. I had a wild idea that I would pivot a swing arm from a 2nd shaft hanger with an English-style straight peddle shaft with 2 peddle arms keyed parallel with tubes welded over for swing arms. All the time thinking the front hanger was going to have bike peddles and sprocket. I didn't think it through too well and I had a situation where there was no room for a sprocket. Anyhow, I don't quit easily. I decided the front hanger would get good bearings and a shaft to serve as a jackshaft. I thought for a bit of using a Sturmey-Archer 3-speed rear wheel with a peddle sprocket on it, but this would rule out the HT. No way to push start with free wheeling. My current thinking is I have several rope start motors, and with a centrifugal clutch, I can put a spring-loaded split pulley from an AC treadmill on the front hanger and use an idler pulley and rocker heel-toe peddle like an old Indian or H-D clutch. With a tight friction clutch it would hold my setting. The other alternative is a long lever with a power hacksaw blade to hold adjustment like a 1910 or so motorbike. I think I might do a tank similar to a Silent Grey Fellow or Marvel either way I go. I think Servi Cycle used the rocker transmission. As for the rear end, extend the swing arms and put shoulder bolts on at the axle slot plates to pivot a front fork, facing down and 2 valve springs on the stem moving in a 1/4" plate mounted behind the seat post. The footpegs will be mounted in a gooseneck from a BMX bike with 4 Allen bolts. The gooseneck is seated in a vertical 5" tube hanging 4" in front of the shaft hanger. I triangulated horizontally back to the juncture of hanger and down tube. I can reverse the gooseneck to change bar position as soon as I overcome the D----ed GALL I raised by sticking a cold gooseneck inside a freshly welded tube and shrinking it tight. Live and learn.. If the front fork would benefit from it I can drop a 1/4" rod from the gooseneck and put a vented plunger ~half way down with a sliding sleeve to shut down the flow of oil on the up-stroke. A 1" X 1/4" double-lip seal will be held by the 1" top fork nut. As I re-read this I realize with proper springs I could put them inside the fork stem and put a pivoting plunger behind the seat post that would be captive with a snap ring under the fork nut flange. This would move in and out the fork stem. Gotta think a bit more KW![scratg scratg scratg](https://motorbicycling.com/images/smilies/satg.gif)
