Rear Drum Freewheel/Control Rod
BigBlue
I found this interesting concept. Builder used a flanged freewheel on the left side to operate a lever that controls drum brake by back pedaling, similar to using a coaster brake.
Here's the original post: http://familycyclery.com/post-yuletime-roundup/
http://motorbicycling.com/attachment.php?attachmentid=67995&stc=1&d=1392752633
http://motorbicycling.com/attachment.php?attachmentid=67996&stc=1&d=1392752648
http://motorbicycling.com/attachment.php?attachmentid=67997&stc=1&d=1392752658
Chris
AKA: BigBlue
that's pretty cool. i've been wanting to make a drum brake with a rod linkage set up for a while now, but never thought of that method.
i was gonna do something like a motorcycle with a brake pedal you could hit with your heel.
Maybe if that can be done, I can make a foot brake to work on my pedal-less motorized build. Although it has V-brakes, a cable to a foot pad that pulls a cable?
But if that is done, then since I don't have a manual clutch hand lever, the centrifugal automatic clutch the reason, I could put the front brake lever on the left handle bar and only have a twist grip throttle on the right handle bar.
I was informed of recent that bikes have the front brake on the left handle bar while motorcycles have them on the right. If I don't have pedals any more and the DMV OHV registration for special construction build says motorcycle, should I have to put the front brake lever on the right handle bar?
Something like the Twilight Zone ehhh!
MT
