Really cheap kit
The cheap kit is not a very good thing, in my opinion, Because its durability is questionable also some of the kits are harmful to the machine.
A couple of other observations. The front and rear mounts use larger tha standard studs and the cylinder is made from something quite different than the rest of the engine. Even looks like steel but it’s not magnetic. Also no white wire out of the magneto. Exhaust port is very rectangular and the intake is the size of the ones on the 66/80cc motors.
Post some pics! :)
An oval exaust port... If you're cameras broke...
Larry that looks like the 48cc I bought a couple of months ago, mine has the open transfers like the G4. Mine runs pretty good, I haven't put that many miles on it so it should get better.
The other thing I jus noticed is that the fuel tank has threads on the outside of the fuel valve connector instead of inside.
Some of the 4L tanks are 12m x1.0... the repop Cruzzer tank is 14m female threads... Maybe something with the new stuff coming out... Honda hobbit is 12m with a clear sediment bowl...
Larry here’s the cylinder off mine, the engine looked good inside, ports were good too.
