Pull Start for 80cc chinese engine
Discussion in 'Motorized Bicycle General Discussion' started by bjpru66, Mar 10, 2008.
  1. bluenosegoat
    bluenosegoat New Member
    Dec 29, 2009
    261
    As I imagined there are problems with the design of the pullstarter. I've been making alot of custom stuff lately so maybe a pull start will be the next project.
  2. Russell
    Russell Well-Known Member
    Apr 19, 2009
    1,205
    25
    If you come up with one, we will all be interested. Please post all info with pictures. The problem that you described(aluminum problem) is the firsrt I've heard of that. Did the center screw come out or did the spring assembly come apart. Could you post a few pictures. Yes I realize how cheap these starters are. When my first one failed(was able to repair it) I ordered a three pack for spare parts. I have had good luck but I do tend to baby it as I know how cheap they are.
  3. shearbf
    shearbf New Member
    May 8, 2009
    77
    It's been a week, so you've probably got it by now. I have three with pullstarts on. Never a problim. I remove right side cover and use a sliver of tough plastic wedged between the primary gears. That way no chance of hurting anything. Some times you need to double gasket the pullstart for clearance of moveing parts.
  4. darkhawk22
    darkhawk22 New Member
    Aug 17, 2010
    733
    I just received a pull start kit from Pirate Cycles and when I went to install it I noticed that I had a lock washer and then a nut on the shaft. I removed these leaving the lock washer on then putting the metal part as it should go securing with the original nut. The Pawl as it looks like it's called moves freely and does not hit the magnet screws as it is far enough off thanks to the original lock washer. However; when I complete the install and pull the cord out, it refuses to go back in. Any ideas? When I take the main cover back off the cord retracts as it should.
  5. SdCruizer
    SdCruizer New Member
    Feb 15, 2012
    108
    I use a brass rod in the gears, brass is softer so no damage can be caused
    takes seconds to loosen too
  6. hiker472
    hiker472 Member
    Nov 6, 2008
    651
    It sounds like there's just enough pressure on that from that lock nut. If you remove the screws, holding it on, just enough to loosen it and give it more freedom, and it works OK, then there is too much pressure on that pawl. Put something thinner in there instead or remove the lock nut altogether and see if that makes a difference.
    If it does stick out just far enough and you don't want to remove the lock nut, you could always grind a little metal off the spinner thing.
  7. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    am I understanding the lock washer is under the sheetmetal piece or under the nut?
  8. hiker472
    hiker472 Member
    Nov 6, 2008
    651
    In between the engine body and the spinner thing. I had a washer there I couldn't leave in there and my shaft was too short to keep the lock nut too, so I had to improvise with a thinner nut. At least it was like this on mine.
    Another thing to question is the amount of pull that is needed to retract the rope. If you don't have a problem with too much pressure from these two things pressing together, then maybe all that's needed is another wind on the rope. If you do, then be careful because if you lift that thing out it may cause the spring to be sprung.
  9. darkhawk22
    Aug 17, 2010
    733
    Update,
    Ok so I removed the lock nuts and washers on the Magneto and re-installed the Pawl and it spins freely now with no additional spacing needed. I secured it with the supplied nut, no lock washer then reattached the outer housing with pull assembly. Same thing happens it still pulls out easily (just compression from engine) but does not retract. I maybe have to do as Hiker says and use a thinner nut to secure the Pawl.
  10. hiker472
    hiker472 Member
    Nov 6, 2008
    651
    Try adding another wind to the rope. To do that and after removing it from the engine, take the rope handle off, let the rope go back in, and turn it another revolution. Use something like vise grips to hold the end of the rope when you do it. Getting the rope back in the hole will be tricky too but it can be done.
    I can't remember now which direction it is to add more tension, but it may be counter clockwise.....which ever way creates a stronger pull on the rope.
