Hi guys, it's time for us to speak up now. Our advice and our opinion is starting to get skewed here. I'm not going to jump on a belt drive vs. chain drive debate here. We've used both systems and we like both for different reasons.
The belts are smooth and quiet and we like that. The belt and jackshaft mounted clutch combination slips more on engagement versus a chain drive with a clutch mounted on the output shaft. Again, this is a good thing for a smooth take off from a standing start.
The jackshaft with chain drive has a very positive engagement (limited slippage). The clutch locks up quicker when it's on the output shaft of the engine because it's spinning faster than it would be if mounted on the jackshaft. As a result the shoes fly out with greater speed and provide a solid lock up. I'm not saying this is better...it's a difference we have noted in the two designs which relates to a difference in feel and performance.
We've built several bikes using both systems. Some of our customers would prefer the belt drive for its feel and smoothness. Others, like us, would prefer the chain drive. We are more focused on racing our bikes and chain is what works best for us on the track. Not saying chain is the best system...just our preference for our application.
As far as maintenance is concerned we've had to replace several belts for our customers as well as several chains. The belt change is a messy job as belt dust is everywhere and gets all over your hands. Changing a chain is no fun either as you get chain lube all over your hands. The chain will last a long time as long as you keep it lubed and maintained. And just like the EZM guys discovered with belts, if you use a quality chain it will last much longer than a cheap chain. Chain noise is not an issue for us. If the chain is aligned, lubed and the tension is set properly the chain will not be noisy. Most of us are using a chain secondary.
Those of you who have met us know we're a pretty easy going group. We're not going to put down anyone's product. We are an EZM dealer and currently have a Q-Matic with a custom shaft length for a new project. We own and ride bikes with belt and chain drive systems.
Sorry this went off topic Wayne. We've been watching your two speed as we've been playing with one too. We hope to meet you at a ride or race so we can talk bikes together. You are knowledgeable and give good advice on this forum.
