Finally got my HF Predator 212 engine running except that it will only run at half choke and the engine will not idle unless you flutter the throttle to keep the RPMs from dropping causing my engine to stall, I have my engine tilted vertical but it runs great once it gets going it just won't idle, even when I turn the idle screw all the way in, any suggestions? Tyler Virga.
