Plug wire/boot failed, cant remove them.
Discussion in 'Motorized Bicycle General Discussion' started by The Busted Nut, Sep 9, 2011.
  1. The Busted Nut
    The Busted Nut New Member
    Aug 2, 2011
    96
    I was riding, and i noticed that my engine was skipping a few fires, and i checked to make sure the plug boot and wire were on snug, and they fell apart in my hands. I tried to get the plug wire out of the CDI, but it is stuck in there. I am going to go to a mower shop and get a new wire/boot setup, but need to get the old ones out first, and i cant!!!
    Please help, i want to ride again :( :-||
  2. decoherence
    decoherence New Member
    Aug 23, 2010
    476
    grab it tightly then turn it counter clockwise.
    it may have been hot glued. so you might have to dig @ the glue.
  3. The Busted Nut
    Aug 2, 2011
    96
    How do i do that without damaging the unit?
  4. decoherence
    Aug 23, 2010
    476
    use a small tool that will not damage the hard plastic. if all else fails take it to the lawn mower place & watch how easy it is done.
  5. The Busted Nut
    Aug 2, 2011
    96
    the people at my local (only) lawn shop are complete jerks. I am not gonna go there. Ill give it a shot and see what happens.
  6. McCuiball
    McCuiball New Member
    Jan 3, 2011
    15
    I used needle nose to hold the wire, and unscrew it counter clockwise while holding the CDI. They look like they are glued in there, but they do unscrew.
  7. 2door
    2door Moderator
    Staff Member
    16,308
    30
    The wire screws into the CDI. Unscrew it like decoherence said. If you find it is also glued then use a small sharp tool to dig the glue out. The new wire will screw back in. Once the wire is out you will see the threaded contact. It looks like the end of a small sheetmetal or wood screw protruding from the CDI's socket. That will screw into the core of the new wire.
    You won't hurt the CDI.
    Also you'll want to replace the plug boot with a good automotive quality part.
    Good luck.
  8. The Busted Nut
    Aug 2, 2011
    96
    I got it out. What store has a good one? Oriely (kragen)? How would a goped one work?
    Also, are short plugs better or worse?
  9. SlowBalt
    SlowBalt Member
    Mar 8, 2010
    759
    Tractor suply sells sets of 4 wires for $9.
  10. McCuiball
    Jan 3, 2011
    15
    I would just get any performance plug for automobiles and cut off the end and screw it in.
  11. decoherence
    Aug 23, 2010
    476
    try to get a copper core. a couple of people have been able to use the resistant type. mine wouldn't start with the resister cores.. so i put a new boot on the original wire & it works.
