Hi first timer here and extremely green grease monkey speaking.
2 stroke 80cc engine.
Both bike and engine brand new, no previous owners.
Bike and engine only just run in btw.
I suspect engine seizure....???
I noticed that prior to this problem when bike was functional, the chain tensioner, where you adjust the wheel bit up or down, the nut was slightly loosened. Rather than tighten it up, I let it be, for some reason I thought this particular nut needed to allow the wheel rotational movement by being purposely slightly loose. Then last week I rode my bike and felt the chain slipping one night.
Almost immediately, the chain unhitched off the rear wheel sprocket and the bike came to a complete stop on it's own, skidding to a stop.
At first I thought it was the chain that needed to be put back on, tensioner fixed and all will be ok.
Not quite, when the clutch was pulled in, to free the wheel and roll the bike for free wheel pedaling, I was not able to free wheel albeit clutch in or not.
I ended up dumping my bike behind the bush, going home to get the tray back vehicle and carted the bike home in shame. Lol...
I'm ****ting myself a little and hoping that I haven't done major damage and that it's repairable.
I appreciate all advice and will attempt to be online very frequently, each day from now, a few times a day, till I fix this issue.
I'm currently in between employment so can spend as much time on this per day as required.
Cheers and thanks in advance.
xo
xo
