justthisguy1292
I had an expansion chamber but it had problems so i took it off and road mufflerless a couple times. I've done this in the past but this time the engine seemed to get a little hotter than usual and it slowed down a bit. i used to max at 40 mph but now i could only hit 30mph after a few minutes of riding. then i put the stock muffler back on to see if it was because i had no muffler. the problem continued and worsened till after a fast run down a big hill the engine stopped dead. the piston got stuck. it didn't completely sieze cuz i was able to wd40 it and knock it lose and get it going again. Its still slow and vibrating alot in mid to low rpm's. should i replace the piston, engine block, both or something completely different? i've heard people suggest a whole new engine at this point but i want to keep this one going if possible. its got a shift kit and custom front mount on it that i'd rather not have to take off and reinstall on something new.
