Yes, I messed with these. I needed to use a vice to force the unit into the small-end. I went through two of them and gave up. They fit well over the pin giving smooth performance, and great for "warning" you that they're going bad (clicking-sound before they have a chance of deteriorating, and destroying your top-end), but I only got a couple hundred miles out of both. Plus, removing the sheath is more trouble than it's worth; you need to Dremel it out. In fact, I damaged a crank doing it; if I DO use that crank again, it'll be as a reserve AND I'll have to use my last HK1014 since there's a decent divot on the OD surface. I've been on a pretty good tear on my present standard needle-bearing; the clearances are tight all around and after about 1000mi, it's all still like-new. I'm just really gun-shy about destroying another jug/rings set (you can always grind a piston back into shape!). I'm tempted to try screwing around with brass-bushings now.
