I got a question. I installed a new bottom end and used my old top end/piston because it was running extremely good.
I drove it for about 2 months and it was powerful all the way to the end (today). Couple days ago I turned up the screw on the carburator to get it to idle without turning off and I had to turn it all the way. After that the engine was way louder and seemed to burn much better but today the piston got stuck in one moment while I was driving just after turning it on.
When I took the head off, I could see a little hole in the side of the piston from the top and the spark as well as the inside of the combustion chamber and the top of the piston was all black with rust - guessing it was running too rich.
I also can see metal scratching down from either the piston or the walls when I look through the exhaust opening. The piston is still stuck and I have to hammer is out tomorrow when its day again so I can buy a new top end. I just hope the crankshaft or bearings didnt get any damage.
Anyways. Is is possible all that happened because I changed it too rich? I personally dont think that makes any sense. It also doesnt seem like the regular case like when its too lean and first you lose power and compression before the engine goes down. It ran perfect, smooth and a second later OFF and stuck.
I also run it with open exhaust but I also dont think thats the reason. Maybe it was just old. Next time I only use synthetic oil again.
