Hey guys im posting this because i bought the otherday a NGK B6HS thinking it was a better plug for performance but i see on the zbox website they say the NGK R7-HS spark plug is better for performance.
Has anyone used 1 of these plugs? are they better?
Another question who has upgraded the lead going from the CDI to the sparkplug with just a lead from a automotive store?
If so what did u get and can u fell a difference?
THanks
DUncan
THanks
DUncan
i'll answer that one.
it stays on.
i replace the plugs (NGK B7's) and wire (7mm copper core) on every engine i build.
the main reason i do this, is the first engine kit i had, the factory wire was brittle and fell apart when i tried to install it. i've also seen a few bikes where the clip inside the wire falls out, and we had to do some Macguyver-ing to get the thing to stay on to get home.
one stock plug i had, the electrode was bent over to the side of the tip at an extreme angle, where if i tried to fire the bike up, it woulda had a severe miss. another one i had was chipped.
also, i like to hide the CDI out of the way, and i need a longer, flexible wire to achieve this.
i agree that in general, upgrading a plug and wire won't suddenly give you 10 horsepower, but it might be the difference between motoring or pedaling home...
I fitted a BP6HS plug to my stock 55cc and it takes ages to warm up. With the original plug, it would come on power as soon as it started, now, I need choke for 2 mins, then it is still erratic for a few more minutes, then it runs ok. I definitely did not see any power gains over the stock plug, if anything I think it is a touch slower up the hills now.
My take on the plug wire, which I have not changed yet, is that they will not give you more power, but if it has less loss than another lead, it will appear to give more power.
That's a plan, will purchase a gap gauge in the morning, I must admit I am using it out of the box.I did have this problem
How to fix this you need to gap the spark plug!!!!
Around 0.25 Inchs
Or aprox 6mm gap
Made my bike goes heaps better!!!!!!!!!!!!!!!!!!!!
Sorry, I should have said that with the stock plug, choke to start, turn off straight away and power avail!!. Just noticed the change after putting in NGK plug. Will gap it tomorrow.And Regarding need to choke this...I thought this is normal..AS i have owned a few of these bike
Normaly put full choke on at start up then move the lever down just a touch ..Than around 100 Meters take choke right off????![]()
