Hello,
I have recently been having a plethora of problems after about 3500 miles with my GT5A. The worst of which is that oil has been making its way into the clutch. And a lot of it. I take the clutch apart, wipe up as much as I can, put it back together with some paper towel in between the pads and friction plate and make it real tight to soak up the rest, take the paper towel out, put it back together and try to start it. It slips for a second but finally starts, but within 5 minutes it's slipping again, and I have to do all of this again, which even then it doesn't work if it's hot. How can I stop all this oil from making it in there, and most importantly how is this even happening in the first place?
When this first started happening, I put in less oil because I thought maybe I was putting in too much. I did this too much and seized the piston, so I replaced the cylinder (luckily I carried a spare, as this happened in the middle of the desert in Mexico) and both gaskets. That might have something to do with it being worse now, but of course it was already happening before.
Also, I have never fully taken the whole engine apart before, I don't have all the tools I need on me. Does old oil normally pool up in there and I'd need to take it apart to empty it out?
Thanks,
Chris
Thanks,
Chris
