OCC chopper front brake
muskie-mike
Here is how I added a front brake to my OCC chopper. Just two u-bolts and some square tubing.Weld the u-bolt brackets to the ends of the tubing.I got the brakes from Amazon.Also put on a dual pull brake lever..
You would also need a disc brake ready hub for what ever wheel you want disc brakes on, so if your forks have the mount for it then you just need the hub with a disc for the caliper to squeeze.
