TedStriker2
I've got another sparkless wonder, and changing the plug and plug wire didn't help. I took the recommended ohm readings, but I could use some help interpreting the results.
Use Low Ohm-Meter Scale About 200 Ohms
Magneto Coil
1) Check Ohms between BLACK wire and WHITE wire. Reading should be around 2 Ohms
My reading: 1.8
2) Check ohms between BLUE wire and WHITE wire. Should be around 300-400 ohms.
My reading: 325
CDI
Use Ohm Meter High Scale About 200-K
1) Positive lead on BLUE wire and Negative lead on BLACK wire should read infinite (no activity)
My reading: no activity
2) Positive lead on BLACK wire and Negative lead on BLUE wire. Should be about 130-150 K-ohms
My reading: 295
3) Positive lead on Spark Plug wire and negative lead on BLUE wire. Should read between 135-155 K-ohms
My reading: 305
Switch to Low Scale 20K
4) Measure between Spark Plug wire and Black lead. Should be about 2.5 - 2.7 K- ohms
My reading: 5
The CDI readings are all high, but I don't know if they're high enough to clearly indicate the CDI is my problem. If anyone out there can say for sure, I'd really appreciate it.
Magneto Coil
My reading: 1.8
My reading: 325
CDI
My reading: 295
My reading: 305
My reading: 5
