freewheeling frank
the biggest sucess i have had with creating a good powerband is with jetting, but i live at 7000 feet once i figure this out maybe then its time for port mods, any other high altitude dudes out there?
Use Threebond 1211 sealant to act as a head gasket, in either case. You also need to check your squish clearence before removing either base or head gasket. you should be running a minimum clearance of 0.7mm squish
it is important to have some room for heat expansion of the piston... very important point.
however, on the other hand. the squish is almost non-existent on these heads lol
I have a grubee GT-2B 48CC.
Replaced head gasket with pop can as gasket material.
I also run the SBP expansion chamber and a home made boost bottle.
Custom made my 36t sprocket.
All in all i run 35 / 40 mph all day long.
Many miles and it still runs good.
Most of the time I run 2 oz octane booster per tank.
Either NOS offroad or Lucas.
I'm thinking i will be changing my bearings to higher quality tougher rated ones.
No head gasket got me as much boost as the expansion chamber.
But high octane runs better.
NO HEAD GASKET 2 THUMBS UP
ok...allot of drag cars will run with no head gasket...the machining tolorances on these are VERY small...sorry but how much did this motor cost???i garruntee you the tolorances are way more...your local machine shop probably cant make these tolorances and if they can you would probably be better off buying ten motors and chancing that there might be a combo that would work(probably still wouldnt find one)...dude all any gasket does is fill these little gaps...thats why they exist...dont try silicone...wont work for very long...tried and true metal,paper,cork,rubber...all have there place and all are according to heat and materials in contact with them...put a headgasket in there for the love of god
