newbie with a few questions
muskyman
Hello everyone,
I just received my first 66cc stinger. A few questions before I jump into it. I tried to remove the spark plug but it is extremely tight. Should I use some penetrating oil before I try to break free? Also the clutch arm on the motor flops around back and forth with out any resistance whatsoever. Is that normal? Any tips or advice wouold be greatly ap-preciated. THANKS in advance.
Jim
Yes,You can use a little penetrating oil to loosen the sparkplug,counterclockwise i believe.
And no, the clutch arm should not flop around, are you sure you have the clutch cable attached to it and is the rod and bearing in there behind the clutch lever gear cover.
