newb needs help
Bikeguy Joe
Jan 8, 2008
11,837
246
up north now
Grind off the outer flange of the dust cover, or grind out the center of the sprocket. The former is faster and easier than the later.
Andretti Green
San Diego
So i have been reading the blogs for a while and need help. I plugged the black wire to the black and blue to the blue. I even saw an arc in the spark plug when i tested it against the motor. What else is there? The carb. seems alright. its new.
Dave31
11,199
45
Aztlán, Arizona
Welcome to the forum :)
Well, you checked for spark and thats the first step...Now you need to determine if you are getting fuel.
I'd crank her over a few times and then pull the plug out to check for signs of fuel.
If no fuel, check the screen inside the fuel tank for blockage (pull peacock out) Also be sure your float is not stuck preventing fuel from getting to the float bowl.
