bigbutterbean
Well, the wheel got here about an hour ago. The spokes had a bit too much flex for my liking, so I went around with a screwdriver and tightened each spoke a quarter turn. I tinged them with the screwdriver afterwards, and they all have about the same tone, so I think I'm good on spoke tension. I had to remove the stock coaster brake so I can install my Shimano coaster brake, and they had the darn thing on there so tight. I loosened the lock nut, but the bearing cone came with it. By the time I got them both off, they were quite warm. But at least they came off. I'll be using the bearings that it came with, since they look pretty solid. I've got to get all the factory grease off so I can put my own hi-temp grease in like I always do. Then re-assemble the hub, get it back on the bike and paint it. But before I do that, also got to remove the jackshaft plate and tighten my crankcase bolts so I stop leaking oil. Got to walk the dogs first though, so I'll check back in when its all done.
