where do i find the right kind of motor to work with your head? the one where the piston goes as high as the top of the jug?
Hi Fuji Moto!
Well, it a bit of a long answer, but I'll try not to blab too much!
As far as the 66/80 cc motors that I have experience with are two types; I don't know all of the particulars for the GT-5SR "super rat" engine because I can't seem to find any. There are a bunch of engines being sold on eBay by companies like "Lucky Early Bird" and "Boy Go Fast". Those engines are the lowest priced units that I know of. These engines will have the highest compression due to the particular piston and connecting rod they use. just make sure it has 8MM studs for the cylinder! Those engines have a older transfer port design.
If you want the best engine, read further about the GT-5 motor:
The newer GT-5 engine is available from Gasbike.net. That engine is a little more money, but it has a better cylinder design. The GT-5 engine uses a "odd ball" connecting rod and piston and requires more material to be faced off the cylinder in order to achieve maximum compression.
All these engines suffer from a disappointing problem of having distorted crankshafts. I suspect the only new engines which are free of this problem is the GT-5SR "super rat" models, which I can't find.
There is hope for these reject engines!
Gasbike.net offers a replacement crankshaft assembly, which I'm told is the crankshaft used on the super rat. I've purchased two of them already, and so far, they are Straight!
So, anyway, I told you this would be long-winded one!
Soon I'll be offering all of the different cylinders to go with the head.
The other thing I can offer is machine shop service, so you can send me your cranks and cylinders for reworking. Cylinder decking is $5.00 and crankshaft straightening and truing is $25.00, not including shipping.
Once you have one of these "reject" engines reworked like this, it turns into a pretty reliable motor. You can also readily get the puller for taking the sprocket and bevel gears off the shafts.
Hope your not too confused!!! Thanks
-Fred
