The glue makes little to no difference, as those two screws modify the pilot jet's air/fuel and idle, not the main/throttle jet.
This is my mini guide to fixing a stock CNS.
1. Tighten both jets.
2. Clear any airleaks at the intake (this may take a while, simplest way is to use a Manic Mechanic intake specifically designed for CNS carbs).
3. Adjust the float.
4. Adjust pilot/idle jet's air/fuel and idle screws (if possible).
5. (optional) Chop the choke cable with about 4 - 12 inches slack from the carb side. Either loop and crimp the cable (4") or roll it up in a series of loops (12"). If your bike is running right, you won't need the choke, and there's no chance of hitting it accidentally on the handlebars.
When I got my CNS tuned up right, it outperformed my NT carb in the 1/4 mile, 33 MPH vs 28. They're good carbs when you give them the chance.
