NEAT TIMES
JIM, I RECEIVED MY SECOND CLUTCH KIT, THANKS.  A HAPPY NEW YR TO ALL RON
JIM, I RECEIVED MY SECOND CLUTCH KIT, THANKS. A HAPPY NEW YR TO ALL RON![]()
Here are the rest of the pics!
I like your clamshell sprocket adapter! Is it quite heavy?
Hi Jim I was looking at the motor mounts and they look great. I was thinking that you might look into the swing arm bushings for some of the small Honda's. Instead of having a bearing they use the rubber filled bushing to let the swing arm move, it also takes out some of the vibs. One of the older Honda CA77's used a larger one but I don't know if you could get any now that was in the 60's. Have fun, Dave
PS: The first Honda 50's had rubber mounts for the engine but for some reason they took them off.
Dave,
Thanks, they worked out really well. The piece that you see in the photos is identical to a motorcycle swing arm bushing, (a rubber filled bushing), they were the upper A-arm bushings for a 73 chevy Nova...exact same concept. And yes the vibration isolation was complete.
Jim
this is a Tohatsu 50 with a top motor mount, what do you think? It is possible that the head from one of these bikes would fit on the happy engine. I had an extra engine for my bike I thought it would still be in the garage but I can't find it. I guess that was thirty years ago. LOL. It would be easy to make long head bolts and then add a bracket to pick up the frame, the 8mm bolts would work the best. Have fun, Dave. bld.
ATTENTION PABLO! - heres what i'd envisage being the best solution
Jim - if you can do us a clutch kit compatible with your intake and those motor mounts, we'd be looking to buy serious quantities
Pablo - If you could either fabricate or team up with Jim to create a similar device to my design, i.e a secure bolt on jackshaft housing along with the other components of your shifter kit, we would be onto serious a winner.
Once tested, we'd fit this package as standard on our bikes as should all other MB vendors/manufacturers.
what do you other guys think?
